Ecu still usable?
Old Apr 13, 2023 | 02:57 PM
Blitzwurger's Avatar
Default Ecu still usable?
Is this catastrophic? It's a P06-L00 out of my 98 integra with a gsr head on a b18b block.(side note, I bought the car already boosted by previous owners and it does run but the wideband shows it runs really lean, idk if it is accurate). I was about to notch the ecu case to install my BMulator and found this.
Old Apr 13, 2023 | 08:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Ecu still usable?
That doesn't look good but it CAN be repaired.
Old Jun 27, 2023 | 08:05 PM
sohc superspec's Avatar
Sorry That this is slightly Off topic - How did the BMulator install go? and Did the kit come with some sort of instructions? looking to pull the trigger on one asap, just not sure of the Data logging situation, if its intergraded now or still requires you to connect wires to the board from the port slot etc
Old Jun 28, 2023 | 04:32 AM
7rrivera7's Avatar
Repairable...
Old Jun 27, 2024 | 11:22 AM
ruinedxjake's Avatar
I just ordered a BMulator to de-HONDATA myself. I can report back with results later.
blacktibby07
May 2, 2011 07:05 PM
MattNYC
Feb 1, 2010 09:09 AM
Ls_vtec dc2
Jul 13, 2008 11:06 PM
XxDemonxX
Feb 3, 2003 06:15 AM
