What ecu and ewh should i use?
Old Apr 9, 2023 | 12:08 PM
BodieEJ8's Avatar
Default What ecu and ewh should i use?
I have a 92 integra ls bottom end and b16 head stamped 91 but I’m going to use 99 parts( vtech solenoid etc etc) what ecu and ewh should i use?
I have the ecu from the ls and the ecu out of my 99 ex civic and the harness from the ls. Should I buy a hondata stand alone and get a rywire harness? If so which one ?
Old Apr 9, 2023 | 08:43 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: What ecu and ewh should i use?
Yes, you should buy a Hondata for tuning since no factory ECU will run the engine correctly. Engine harness choice will depend on what chassis you intend to stick the engine in.
Old Apr 10, 2023 | 04:28 AM
BodieEJ8's Avatar
it’s going in a 99 civic
and do I need a p28 with hondata in it or p75 or some other one?
Old Apr 10, 2023 | 08:33 PM
JRCivic1's Avatar
10 Year Member
Community Builder
A P28 with Hondata is a good choice. The P75 would have to add VTEC components to the ECU to make it work... either way, you will need that Hondata S300 to tune the engine. If you find a '99-00 Civic Si engine harness, it will be essentially "Plug-n-Play". A '99-00 Civic EX manual engine harness will work too with minimal modifications.
feriotypeR
Jun 16, 2009 12:20 AM
eric p
Feb 7, 2009 04:25 PM
99ctrek
Sep 30, 2008 11:20 AM
93dagsr
Jul 31, 2007 01:52 PM
camelian
May 5, 2006 02:18 PM
