Abs Issues with Aftermarket steering wheel and deletion of steering wheel airbag
1997 Honda Accord Ex with 2.2L F22b1
Hi so I have ran into a problem with the abs, after installing a disconnectable steering wheel and deleting the airbag my srs light has turned on which makes perfect sense but im also now having the issue where when driving the moment the wheel slips at all I loose all brake pressure in the pedal, then it comes back after giving it a couple pumps. I also just tryed to reset the code for the srs to try to trick the system into thinking there is airbag still connected and it would seem to work. Any help would be awesome, and if this problem has already been solved than a link would be awesome thank you!
Finger Lickin' good
Mar 27, 2005 04:57 PM
SalmanzCivic
Dec 30, 2004 06:25 PM
lePetitePrince
Jun 4, 2003 01:27 PM
