Honda Del Sol 1993 - Indicators Not Working
Old Apr 6, 2023 | 05:17 AM
Mo0nShad3's Avatar
Default Honda Del Sol 1993 - Indicators Not Working
Hi there, I have an issue with my Honda Del Sol 1993 where the indicators do not switch on for both sides of the car. However, when pressing the hazards switch on the dash, all of the indicators flash correctly. This shows the bulbs are working and I do not believe there is a blown fuse.
My question is what sort of thing would cause this issue?
Thank you in advance for any help.
Old Apr 22, 2023 | 05:20 PM
countrynoob's Avatar
From: Whats Up MN!! But still the middle of nowhere...
Default Re: Honda Del Sol 1993 - Indicators Not Working
If you using your turn signals aren't working, you may have a bad turn signal switch as it will supply the appropriate circuit to the respective side you turn it to. The hazard switch on the other hand, completes both circuits for both turn signals when depressed.
Old Sep 3, 2023 | 04:25 PM
lillyahoo's Avatar
Is the turn signal switch the column switch?
Old Sep 3, 2023 | 08:04 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
On a USDM Honda, it is the LEFT stalk on the steering column.
Frankenfurter
Jul 16, 2021 05:05 PM
ssdiablo87
Sep 6, 2004 12:23 PM
