Car won’t start after stalling
92 civic hatchback d16y5 on stock p28 ecu obd1
long story short i’m a new manual driver so i’ll stall in first and when i do the car doesn’t want to turn back on right away after about 2 minutes or multiple tries at trying it will turn on just fine again.. just looking for any ideas what it may be i want it to turn on right away
Could be a weak starter.
Hold the clutch down more and give it more throttle to control the take off in first gear, basically don't release the clutch so fast and give a little more gas than clutch and once it starts moving release the clutch all the way, you will get the hang of it.
When it happens does the starter crank but not start or is it a no crank no start
Also does the cel come on and off like it should do you hear the main relay
88B20CRX
Jul 24, 2004 01:00 AM
