1993 Civic "electric like" noise when under load.
Old Mar 29, 2023 | 03:43 PM
william14's Avatar
Icon4 1993 Civic "electric like" noise when under load.
Hello everyone! I have this problem on a 1993 Civic. When you accelerate in while under load (on a hill or something), it starts making a weird noise like an spark or electric noise. Other symptoms that I was able to see are power loss and consequently overheating, clearly when the noise is happening. Checked distributor and the only interesting that I found was that it has a bit of oil into it, I do not really now if it could be related. Also checked ignition timing and was a little off, I fixed it but the problem is still there (Now it is just a little lower). Any ideas on what the problem is?
Note: It only happens when the engine is under load, if you accelerate in flat it does not make the noise, only when you are almost full on the gas pedal.
Also, I managed to record the audio. Sorry for all the wind, but I think you will be able to hear it.
All help is truly appreciated
File Type: mp3
Golfnut
Jun 26, 2013 08:38 AM
prues32
May 28, 2008 12:43 PM
wxy117
Mar 24, 2008 10:26 PM
easyFOsheezy
Jun 30, 2005 02:29 PM
