Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2004 Manual Transmission Help
Old Mar 27, 2023 | 05:01 AM
Sebpiagg's Avatar
Default 2004 Manual Transmission Help
light whirling or grinding while clutch is out in neutral sounds like input shaft bearing but when the pilot and throwout were bad it wasn’t making this noise all new kit with everything was installed now makes a quiet whirling grinding rotational noise when I press the clutch in it goes away , any help is appreciated
Old Mar 28, 2023 | 06:13 AM
benchwarmer's Avatar
5 Year Member
Default Re: 2004 Manual Transmission Help
You may not have notices the input shaft bearing or it decided to make noise after you replaced the other parts . The whole gear set has to come out to get to the input shaft bearing so I can see how some may skip that part . I drove one with a bad input shaft bearing for many miles , it sounded like hell but never caused a problem
Old Mar 29, 2023 | 05:20 AM
Sebpiagg's Avatar
yeah it’s not loud like barely a difference but enough to notice it, also missing a mount bolt and a bell housing bolt can that hurt things?
Old Mar 29, 2023 | 05:57 AM
5 Year Member
Missing bolts certainly don't help . It leaves the other bolts under more stress and they should be installed . Get them from honda as they may not be standard or metric . Honda has their own thing going on .
Old Mar 29, 2023 | 08:49 AM
Ryanthegreat1's Avatar
Honda bolts are all metric to the JIS standard. Nothing strange going on here.
kyle0209
Oct 20, 2016 01:59 AM
Gus21723
Transmission & Drivetrain
Dec 9, 2015 07:49 AM
kriptik
Apr 16, 2004 02:49 AM
PoWeRBaN_PaNdA
Oct 20, 2002 05:45 PM
