Camgear setting. Need opinions
Hi. I need some opinions on what is ideal camgear setting for my build.
B16a jdm
81.5mm nippon racing type r style pistons
ported head (unmilled)
undecked block
sKunk2 tuner 2 cams
aem cam gears
550cc injectors
skunk2 pro intake manifold
Blox 74mm throttle body
Aem fuel rail and regulator
320lph fuel pump
P1 buddyclub ti retainers and springs
Skunl2 flat valves
Skunk2 alpha headers
Honda oem head gasket
skunk2 lost motion
Thank you.
B16a jdm
undecked block
sKunk2 tuner 2 cams
aem cam gears
550cc injectors
320lph fuel pump
Skunl2 flat valves
skunk2 lost motion
Thank you.
B16a jdm
undecked block
sKunk2 tuner 2 cams
aem cam gears
550cc injectors
320lph fuel pump
Skunl2 flat valves
skunk2 lost motion
Thank you.
B16a jdm
undecked block
sKunk2 tuner 2 cams
aem cam gears
550cc injectors
320lph fuel pump
Skunl2 flat valves
skunk2 lost motion
Thank you.
