Weird idle problem
Old Mar 14, 2023 | 02:43 AM
Brokenfitting's Avatar
Default Weird idle problem
I have a 1998 civic hatch swapped with a b18c1 block with a b16 head. The engine would start up no problem but if the engine is cold/ start start. Still starts up good put it in gear, drive to the closest stop sign or light once the car comes to a complete stop the car stalls. Thai would happen till the car was hot. And it also surges between 1k all the way down to 100. Only at a stop I could be in neutral rolling to a stop and it won’t surge but once I stop it starts.
I noticed my tps was messed up so I changed it now the car doesn’t stall on start up but still surges. And man is it never racking driving it in traffic while it surges to a point where it almost stalls.
Things Ik about the motor is it used to be used for drag and has cams. Also had a nos set up before I removed it. Could it be timing?
Old Mar 14, 2023 | 02:54 AM
Default Re: Weird idle problem
Could it be a vacuum leak? Wouldn’t it be the other way around. As in I’d have a higher idle
Old Mar 14, 2023 | 11:18 PM
Bump
Old Mar 16, 2023 | 07:26 AM
Never mind learned the hard way again that it still does stall when cold. Any help?
Old Mar 19, 2023 | 09:36 PM
Bump
Old Mar 24, 2023 | 01:43 AM
Help?
Old Mar 29, 2023 | 10:17 PM
Bump
Old Mar 31, 2023 | 12:29 AM
Help me please?
lkiss
Honda Civic (2001 - 2005)
Mar 22, 2016 10:20 AM
TwistedEX
Sep 10, 2011 08:27 PM
TrueUntilDeath.com
Sep 25, 2009 09:13 AM
blackludebosh
Aug 8, 2008 10:37 PM
square_1
Nov 12, 2006 10:13 AM
