Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
Short and Long Term Fuel Trim
Old Mar 12, 2023 | 01:21 PM
gjgogol's Avatar
Default Short and Long Term Fuel Trim
I have a 2013 Honda Accord EX 4 CYL w/155K miles and am in the process of running down P0420 code. It has been suggested that it is a bad CAT. When I spoke to a CAT manufacturer they said that a CAT usually just doesn't go bad on its own and that something else is likely causing the problem. One of the metrics I am checking is the fuel trim numbers and according to my FIXD report the trim values are 3.13% for STFT and 2.34% for LTFT. I have read that values normally range from -10% to +10%, but I am not sure if this is correct. Are the numbers I am getting in a satisfactory range?
Old Mar 17, 2023 | 10:19 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Short and Long Term Fuel Trim
"Cats dont fail" is an old school of thought that ignores the changes in size,weight, and modern fueling and catalyst monitoring strategies.
On most modern vehicles if the efficiency falls below 99%, that cat is deemed a failure.
Despite the fact that the cat will easily pass a sniffer( emissions analyzer,) the PCM relies heavily on the EWMA formula and will deem the cat a failure if it falls out side of its parameters.
Long term trim is considered "good" if it falls between -10 to +10. These numbers rarely change and represent the overall fueling strategy. Perfect trim would be 0% and the closer you are to that number the better, but you wont see that on any current vehicle.
Short term trim is a representation of real time fueling strategy. As such, this number will oscillate during driving. -5% to +5 is ideal.
If the trim numbers are good, there are no exhaust leaks and there are no PCM reflash updates for this code, then you need a cat.
Cat monitors are very robust and very rarely(if ever) set a false code on a modern vehicle.( if the above conditions are good)
Old Mar 17, 2023 | 11:18 AM
gjgogol's Avatar
I have also tested ignition coils (COP) and am getting a 1.2 ohm reading on all 4 (cold). Any chance that the coils can go bad (throw a P0420 code) when heated during driving? I blew air up the tailpipe and found no leaks. In fact I removed the F/A sensor on the front cat during the process of blowing air in the tail pipe and experienced pretty good air flow coming out the port...so it appears that the cat is not clogged. My check engines light is intermittent. Is that consistent with a bad cat or maybe more like bad coils?
Old Mar 17, 2023 | 11:20 AM
Ryanthegreat1's Avatar
There is no easy way to tell you this. Your cat is dead. Sorry for your loss.
Old Mar 17, 2023 | 11:34 AM
gjgogol's Avatar
So does that mean it died on its own and likely that NOTHING caused it to die? Would a dead cat be clogged? Really don't want to invest in new cat if its going to die due to external causes.
Old Mar 17, 2023 | 11:48 AM
How many miles are on it? They don't last forever. I have had a few modern Hondas only get 60k out of their original cats. Oddly they were all out of California. Guess California causes cancer in cars too?
Old Mar 17, 2023 | 01:37 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
HA!!
Old Mar 17, 2023 | 01:42 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
All things being equal, heat and vibration will cause it to die past 100k.
I wanna say modern vehicle cats probably last around 100k-150k. Of course there are always outliers but in my considerable experience, thats the average lifespan....
Old Mar 18, 2023 | 12:41 PM
gjgogol's Avatar
My accord has 155K miles on it. If I do need the cat, any recommendations for a cat and where to get it )preferable without breaking the bank)? Honda dealer wanted $2K!
Old Mar 18, 2023 | 03:26 PM
OEM Honda. The aftermarket cats fall apart in about 20k miles.
Might save a little up front but they don't last. Either the honeycomb inside breaks apart and blocks the exhaust or they start tossing another P0420.
Nothing cheap about doing this correctly. The precious metals inside that nake it work are crazy valuable.
Old Mar 18, 2023 | 04:12 PM
gjgogol's Avatar
ugh...how about cats from rock auto?
Old Mar 20, 2023 | 06:48 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
If its CARB approved it will be as good as a dealer cat.
Otherwise its a crapshoot.....
Old Mar 20, 2023 | 07:23 AM
gjgogol's Avatar
Thanks to everyone for your responses!
adk133
May 6, 2025 11:27 AM
Hondacommuter
Sep 18, 2017 05:49 AM
danteisme
Dec 1, 2008 07:49 PM
Kchao707
Northern California (Sales)
Oct 22, 2008 10:05 PM
denmick
Jan 4, 2007 05:07 PM
