removing gas from my 96 honda accord ex 2 door
There should be a drain bolt on the bottom of the tank. If not, unhook the feed line before the fuel filter, jump the fuel pump to the battery, and pump the tank empty.
I have had good luck disconnecting the return on the side of the tank.
Using an air compressor nozzle and a rag in the gas cap hole put some pressure in the tank to start a siphon,
My replacement tanks don't have a drain plug.
dylanjwanroyale
Jun 10, 2015 03:49 PM
WS6Fury
Mar 21, 2002 04:44 PM
