93 4ws build advice
Hey yall,
Im new here, ive got a 93 si 4ws that i want to make awd, i was wondering how feasable that was, and also if i should swap to an h22 or just do the head swap, any advice is appreciated
LSD would handle most traction problems unless you were aiming for ego boosting or absurd power, in which case you would probably need K-series CRV drivetrain, even though they are usually only 4wd once the front has lost traction, so only good for snow or drag racing with no advantage in grip out of corners.
