Am I able to run my car with forks rotated 180 degrees?
So my friend got me ebays front uca, i set it to max camber so my wheels will fit under my fender. The problem now is my forks/wishbones rub and grind on the axle. I can even see the raw metal mark on the axle. So I flipped them, rotated 180 degrees and it doesn’t grind anymore. I was wondering if any of y’all knew if it would be ok to run it like this?
If they are hitting the driveshaft, I imagine that you already had them swapped left to right or installed backward.
Guys i have no idea how to fix this, if i do full degree turns when parking or something the axle still hits the fork (my forks are flipped backwards right now if i flip it 180 degrees back (how oem is) itll cut half the axle with time
88_T-Rex
Feb 3, 2006 09:59 AM
