2000 honda civic si ringing noise
I have a 2000 honda civic si and there’s a constant ringing noise, i thought it was a vacuum leak but i got that fixed and it’s still making the noise. Anyone have this issue or know what it could be ?
edit: I tried attaching the video but i don’t think it’s working, it’s coming from the drivers side of the engine bay if that helps.
Try to put something up on YouTube and attach that here. If you can't can you better try to describe the ringing noise?
Does the noise change with RPMs? Does it go away at a certain RPM or get louder when you change something?
From the diver's side it could any number of things:
Alternator bearing
A/C compressor (If applicable)
P/S Pump (If applicable)
Timing belt tensioner
If you have a small hose, you can try to put one side in your ear and move the other end around the engine bay to see if you can further isolate it. You can also do the same with a long screw driver: handle side on your ear and touch the metal tip to various pieces of the engine. Obviously be careful of moving parts.
One other thing is to get the motor running and slowly, and carefully unscrew the oil cap. Don't fully remove it, but lift it just a little bit and listen if the noise gets louder indicating it might be coming from the valve train.
Alternator bearing
95inthe530
14
Jul 13, 2011 08:46 AM
josephmartins
Jan 20, 2005 06:55 PM
