EJ8 Window Tension Breaking
Old Mar 4, 2023 | 06:24 PM
B34R's Avatar
Default EJ8 Window Tension Breaking
EJ8 98 2dr EX driver side window keeps breaking clips. I’ve replaced them and replaced them but the front one keeps snapping on the inner prong. It looks like the front track is too tight or bent somehow. I’ve pulled it and it matches up to the window and everything. I’m thinking that the window regulator arms were bent and they were. So I went to order new Regulator arms from O Reilly. They fit but then my motor didn’t fit into the assembly? It had an extra tab that blocked it. I looked it up and found I got a 740737 assembly but Rockauto sells 741737 do these fit? Are they that specific? I’ve done research and can’t find diddly squat. Also if this helps my button to roll down the windows is wonky, when you push down the window goes up and the same for the opposite. Could it be the wrong motor and plug then? I’m at a loss tbh. I’ll send some pictures tomorrow for reference, thanks!
bckid
Honda CR-V & Element
Jan 2, 2016 11:44 PM
intgraCA
Jun 21, 2007 08:00 PM
bleedblue94
Nov 7, 2006 02:48 PM
