VSA and TC Light On (2009 Civic Si)
Old Mar 2, 2023 | 11:39 PM
808load's Avatar
Default VSA and TC Light On (2009 Civic Si)
TL;DR - VSA & Traction Control light is on after wiring subwoofers, VSA button doesnt work and i have 3 VSA codes.
Decided to add subs to my sound system after 2 months with the car, couldn’t find a way to run the power cable for the amp, so i thought of a dumbass idea to poke a hole through this rubber piece in the firewall where a harness was also going through. Might’ve punctured a wire and that could be the reason why but i have no clue if it is. Everything was good, subs were ok, but after a drive around i quickly noticed my VSA and TC on. Used a OBD2 and got 3 codes out of it (27-11 Steering Angle Sensor Diag Signal Error, 86-1 F-CAN Bus-Off Malfunction,83-13 ECM/PCM Relation Failure. I wanna know what i really messed up on, what wire, cable, fuse, module, idk. I cant seem to figure out where to start. Im stuck at a huge loss here, car seems to drive horrible now too. Someone save my car.
Rubber around harness where i decided to poke a hole through, so i can run the power cable for the AMP, i think i might have punctured a wire and thats why i have the lights on but i cant get the rubber off to check. ( I know, theres an easier way to run the cable through)
Old Mar 3, 2023 | 07:24 AM
Ryanthegreat1's Avatar
Default Re: VSA and TC Light On (2009 Civic Si)
Pull the harness out and inspect it for damage. I believe the steering angle sensor runs through there out to the ABS module.
Dead CIVIC
Audio / Security / Video
20
Apr 22, 2013 08:33 AM
K I T T
Honda Civic (2006 - 2015)
Aug 14, 2006 05:00 PM
Blade121
May 21, 2006 01:28 PM
phreakmang
Mar 12, 2004 04:21 PM
crxguy05sir
May 18, 2003 05:42 PM
