Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
How is this possible? Cyl 2 rocker arm not moving
Old Mar 2, 2023 | 04:20 PM
dcnaz's Avatar
Default How is this possible? Cyl 2 rocker arm not moving
2013 v6 with 180k, misfires on cyl 2, checked coils, plugs, fuel all good. Pulled cover off. Was a bit loose on the cyl 2, so i adjusted the valves just a tiny bit. But for some reason this middle part rocker is not moving at all, how is that possible?
File Type: mov
Old Mar 3, 2023 | 05:19 AM
dcnaz's Avatar
Default Re: How is this possible? Cyl 2 rocker arm not moving
No one ever seen or had this situation before?
Old Mar 3, 2023 | 09:19 AM
Ryanthegreat1's Avatar
Part of the VCM system. Looks like the pin is stuck disabling that cylinder.
Old Mar 3, 2023 | 09:29 AM
dcnaz's Avatar
Do you know how it looks like or if there is a video addressing it?
Old Mar 3, 2023 | 10:43 AM
It's the same idea as how VTEC works but it disables valve lift rather than increasing valve lift.
Old Mar 3, 2023 | 11:42 AM
dcnaz's Avatar
I understand, but this is where i have a misfire, i tried turning it over many times but its always stationary, is this normal? Am suspecting something isnt right. Car is cold too. Maybe like a pin or something that holds the rocker arm down or moves it
Old Mar 3, 2023 | 11:48 AM
I don't think it's normal. There are a set of pins that slide between those three rocker arms locking and unlocking the middle arm to the outside arms.
I believe the default is they are locked together until VCM applies oil pressure unlocking the arms to disable the cylinder.
Old Mar 3, 2023 | 12:06 PM
dcnaz's Avatar
Lol so what you saying, the other 2 cylinders move like they should, so maybe its an issue with the pin? By removing those top bolts holding the whole assembly will i be able to tell? But of course after that ill need valve adjustments
Old Mar 3, 2023 | 12:55 PM
I believe there is a solid rail that goes through all those cam caps and rocker arms. You will have to remove ALL of the rocker arms to inspect that one.
Old Mar 3, 2023 | 01:09 PM
dcnaz's Avatar
Thanks, very helpful. Strange that no one ever had this issue
Old Mar 3, 2023 | 01:17 PM
Oh probably plenty of people have had the issue, they just dump it at the dealership and when the dealer says that will be $2600 to fix they trade in the car and are done with it. Not too many people still turn wrenched in the driveway and then even fewer make it to the internet to post about it.
Old Mar 3, 2023 | 01:41 PM
dcnaz's Avatar
Wow, so have you see this before? Where one if the rocker arm on a cyl not move at all?
Old Mar 4, 2023 | 04:33 AM
dcnaz's Avatar
I believe i found one of the piston caps stuck in one of the rocker arm hence not assisting in moving it, but putting the whole bridge assembly together is a nightmare. Ton of springs and caps ugggh, i cant find any info on how to put it together
Old Mar 4, 2023 | 06:18 AM
dcnaz's Avatar
Old Mar 4, 2023 | 06:33 AM
Oh boy.
I don't have a service manual with a VCM head. Honda does offer access to the service data for $25 a day. You can save the data as a PDF or print it for use later.
https://techinfo.honda.com/rjanisis/logon.aspx
Old Mar 4, 2023 | 08:47 AM
dcnaz's Avatar
Its complicated unfortunately with all the kittle parts, no diagrams at all that i can get to figure it out, look at this
Old Mar 4, 2023 | 12:55 PM
dcnaz's Avatar
If the valves on that cyl are bent shouldn't the rocker arm still move?
Old Mar 4, 2023 | 03:08 PM
Yes the rocker arms will still move with bent valves.
Old Mar 4, 2023 | 03:20 PM
Rear cylinder rockers
Old Mar 4, 2023 | 03:24 PM
dcnaz's Avatar
Thanks, this is verynhelpful. Is there a way to tell if my motor is pzev?1HGCT2B81DA011738
RockerArmMan
Apr 24, 2022 09:09 AM
markyd48
Dec 9, 2010 09:23 AM
Scorchin Civic
Jan 31, 2010 06:22 PM
Nutcase4life
Nov 9, 2007 10:10 PM
95 Quelude SI
Nov 1, 2006 02:45 PM
