Civic eg Service connector
Old Feb 28, 2023 | 02:05 AM
LittleHesus's Avatar
Default Civic eg Service connector
Hello guys , I have a eg and I was wondering if there is a male plug for SCS which I could buy in order to debug any issues without using a paperclip or something. just plug it and be done with it
Is there a part available for it or the only solution is to use a paperclip?
I am talking about the 2 pin connector on the passenger side on top of the ecu
Old Feb 28, 2023 | 08:01 AM
bumpstick's Avatar
Default Re: Civic eg Service connector
Sumitomo HD090. You can still buy them brand new.
If you hunt the junkyards you can find the corresponding end in 96-00 EX Civic tweeters, IIRC
Old Feb 28, 2023 | 08:19 AM
Thank you so much for the fast reply , found it and in europe which is really good!
By any chance does Sumitomo makes the ECU (Obd1) connectors aswell and pins and by even greater chance do you have the codes for the large and small pins?
Old Feb 28, 2023 | 09:20 AM
spAdam's Avatar
Loved
Community Favorite
The ECU connectors are not Sumitomo, they are TE/AMP Multilock 040/070 Hybrid series. They should be available from Farnell or similar in Europe/UK.
Old Feb 28, 2023 | 10:22 AM
Thank you!!
Old Feb 28, 2023 | 07:39 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You can buy the factory service connector jumper from your local Honda Parts Department... if you need the part number, I can post it tomorrow.
Old Feb 28, 2023 | 11:30 PM
Oh , that sounds great! If its not too much trouble that would work out!
Xayne lopez
Mar 17, 2016 07:51 PM
Stevegunit16
Jan 2, 2007 10:17 PM
LD-rhdEG6
Mar 1, 2006 06:57 AM
soundman
Jun 10, 2004 07:47 PM
