K24 vs K20 weight, physical height
Old Feb 27, 2023 | 09:19 PM
juda's Avatar
Default K24 vs K20 weight, physical height
Just wondering the weight difference and physical height difference between the k20 and k24, i am swapping this into my 2100lb civic hatch and if the k24 will negatively affect the handling ill go with the k20
Old Feb 28, 2023 | 06:02 AM
Ryanthegreat1's Avatar
Default Re: K24 vs K20 weight, physical height
They are nearly identical in weight. The K24 just has an extra 13mm of deck height and the small amount of weight associated with that.
A fully dressed K24Z7 with transmission as it comes in a 9th Gen SI is 474 pounds.
Old Feb 28, 2023 | 05:22 PM
juda's Avatar
ok so it sounds like the weight difference wont even be noticeable then, thank you
Old Feb 28, 2023 | 07:52 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The actual difference in height between the K20 and K24 block is 19.7mm... basically 3/4". The exact weight difference escapes me right at this moment... but I think it is only about 20 pounds.
Slowass2dr
Mar 7, 2007 12:48 PM
bluesaint
21
Sep 15, 2006 12:05 PM
Almypal
Mar 10, 2004 12:43 PM
sayjdm
Nov 11, 2002 12:47 AM
