UK Type-R intake valves
Old Nov 18, 2002 | 08:42 AM
satan_srv's Avatar
Default UK Type-R intake valves
Hey my engine builder was telling me to try and find some UK Accord Type-R (edited not ITR!) intake valves for my H22a head, stating that something to do with the angle/design made them flow much better.
Does anyone have an info on these, or where I could get them? Thanks.
[Modified by satan_srv, 10:35 AM 11/21/2002]
Old Nov 18, 2002 | 09:01 AM
satan_srv's Avatar
Default Re: UK Type-R intake valves (DOHC_VTEC)
uhh... i don't think that'll work.
Why not? As far as I know it has already been done....You can also use ITR lost motion assemblies on H22a...
Can anyone confirm what was said about the UK specific intake valves? I didn't make much sense to me but he's built a lot of engines..
Old Nov 18, 2002 | 12:51 PM
satan_srv's Avatar
Default Re: UK Type-R intake valves (satan_srv)
So is he on crack? Does anyone know about these? Hmm I have been told they are all the same...what the hell...
[Modified by satan_srv, 4:59 PM 11/18/2002]
Old Nov 18, 2002 | 04:19 PM
ismkv8s's Avatar
unless there valves in the uk are 35mm intake and 30exhaust they won't fit! stock b's are 33mm intake and 28mm exhaust!
Old Nov 20, 2002 | 10:59 PM
satan_srv's Avatar
Default Re: UK Type-R intake valves (ismkv8s)
Yeah I talked to him again...he meant Accord Type-R i.e. H22a
Old Nov 21, 2002 | 06:26 AM
aklucsarits's Avatar
New User
Supposedly, the JDM Prelude TypeS has a unique head design with different valve angles than the regular H22A. The Accord Type R and Accord EuroR may use this same head. The valves may be different, but they also may not be compatible with a regular H22A head...
Andrew - who is mostly just speculating...
Old Nov 21, 2002 | 06:32 AM
satan_srv's Avatar
Default Re: UK Type-R intake valves (aklucsarits)
That is correct, it's the valve angles
I have a thread a few down where I am looking for them. But so far the price seems hella expensive (like $500 US or Euros) for anll 16. I may just spring for the intake valves....
Old Nov 21, 2002 | 06:43 AM
New User
I'm not understanding... Do you want the just the ATR valves? Or do you want a whole ATR head?
The point I was trying to make initially is that the ATR valves may not be compatible with the "regular" H22A due to the difference in valve angle design in the head itself (if the ATR head is indeed similar to the JDM TypeS head)... Again, I don't know for sure. Just speculating...
Andrew - who likes to speculate about the worst case scenario
Old Nov 21, 2002 | 08:31 AM
satan_srv's Avatar
Ohhh.....I thought you meant the angle of the bottom of the valve for faster velocity or something...that's what I was referring too. I don't think there is an actually angle in the head issue....
Old Nov 21, 2002 | 08:37 AM
ludespeeder's Avatar
what about those guys that had h22a4 heads and pu tin Type-S cams ang got funky wear or valve lash problems?? i thought that was from the valve angle in the type-S head vs. the angle of the USDM head...??
Old Nov 21, 2002 | 12:28 PM
pentaq's Avatar
They are the same as in Prelude. Sent you some pix.
pentaq
Old Nov 21, 2002 | 01:16 PM
New User
Default Re: UK Type-R intake valves (pentaq)
pentaq
Pics? Post them! Post them!
Andrew
Old Nov 21, 2002 | 01:20 PM
satan_srv's Avatar
pentaq
Andrew
I will when I get home Mr. Pessimist!!
Old Nov 21, 2002 | 02:42 PM
satan_srv's Avatar
They are just screen shots from his Honda Electronic Parts catalogue...
Both part numbers say P13 for Prelude VTEC and ATR.....and are the same...
So maybe it's only Type-S and SiR-T valves.....maybe Euro-R
Old Nov 21, 2002 | 02:48 PM
93 VTEC's Avatar
Are the last three digits of the P/N the same? That is where the difference would be if there was one
Old Nov 21, 2002 | 03:40 PM
satan_srv's Avatar
Default Re: UK Type-R intake valves (93VTEC)
These were the numbers:
14711-P13-000 Valve IN
14721-P13-00 Valve EX
Old Nov 22, 2002 | 12:51 PM
Mikeyslude's Avatar
according to inlinefour there are mods which have to made so it will work properly but they also said Skunk2 is releasing an almost identical manifold around January which requires no mods.
Old Nov 22, 2002 | 02:16 PM
satan_srv's Avatar
Default Re: UK Type-R intake valves (Mikeyslude)
? THis is about valves, not Intake Manifolds
aeros
Apr 29, 2014 08:08 PM
sup3rd
Nov 26, 2007 06:30 PM
Art701
Apr 12, 2004 09:05 PM
satan_srv
Nov 23, 2002 10:30 PM
HotWheelz
Oct 17, 2002 05:29 AM
