Automatic Transmission Install Woes
Old Feb 25, 2023 | 03:49 PM
WorstMechanic's Avatar
Default Automatic Transmission Install Woes
Hello,
Recently I picked up a $500 1999 civic with the intention to fix it up for my girlfriend, and I've been running into a roadblock installing the auto trans onto the engine.
The other day I mated the two by twisting and jerking the transmission onto the engine, smacking it with a rubber mallet once I had it "mated" and snugging up the bolts. When I attempted to turn the engine over in order to set timing for the distributor, I noticed it would not budge. I removed the transmission, and when the engine turned over I marked it up to a seized transmission. After researching the topic more, I learned the torque converter was supposed to be installed onto the transmission, aligned, then installed as an assembly onto the engine, and I likely failed on the oil pump alignment
In a few threads that I've read here on the forum I am under the impression that if I simply reinstall everything correctly I will not have anything to worry with, but on other forums for other cars it's implied that the transmission oil pump is likely crushed and I will need a new transmission. What is the case for the Civic, and should I cut my losses and install a fresher junkyard unit instead?
Thanks!
Old Feb 26, 2023 | 03:00 AM
Default Re: Automatic Transmission Install Woes
Bump, I'm hoping to get an answer on this so I can try and wrap up this portion of the project today.
spazwell
Jan 31, 2012 04:48 PM
JDM00SI
Nov 9, 2005 09:19 AM
SiMateoAko
21
Sep 9, 2005 11:18 PM
manwezy951
Apr 5, 2005 01:56 PM
