Speedometer not working 95 VX Hatch
Read a bunch of things saying it’s the Speed sensor, connector or gauge itself. Wanted to see if there are signs for each specifically.
The needle is behind the post below 0 and revs up to the post as I accelerate.
odometer and trip meter still work.
No Engine light.
Sorry, just hate errantly swapping pieces.
thanks in advance!
No Engine light.
thanks in advance!
If the odometer and trip meter are still functioning properly, then the VSS is working and the wiring is good. Your speedometer is malfunctioning/damaged.
Honda speedometers are known to go bad. Back in the day, I had to replace the gauge cluster in my dad's '94 Accord DX sedan. Car was only 3yrs old then, with less than 30k miles.
Fixed.
Pulled the cluster and Speedo out. Inspected the board and found the connectors had a halo around solder points. Resoldered the connectors and Speedo is running again.
twinturboguy
31
Nov 8, 2013 10:46 AM
twinturboguy
Oct 24, 2013 04:21 PM
