Cluster Temp Gauge
Old Feb 20, 2023 | 06:12 PM
Kcan25's Avatar
Default Cluster Temp Gauge
Hey guys, new here. How do I get my temp gauge to work on my stock cluster after k24 swap in em1?
Old Feb 20, 2023 | 08:50 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Cluster Temp Gauge
Your swap harness/conversion harness should have a yellow/green wire on it for this. You would mount a single wire ECT sensor and connect the yellow/green wire to it. If you mount the sensor in the water neck housing, it will work as-is. IF you mount it in the radiator, or use a cheap upper radiator coupling adapter, you will have to run a ground to either of these parts to make the gauge work.
Old Feb 21, 2023 | 04:47 AM
Kcan25's Avatar
thanks, I’ll take a look today if I get some time
f575gtc
Honda Civic (2001 - 2005)
Jan 16, 2015 01:48 PM
VTEC_Honda
Apr 14, 2010 12:43 AM
