1992 accord engine removal
Definitely up and over. Remove the 3 mounts if doing engine only and make sure the engine is hooked to the hoist. Check the bolts on the engine hook tab loop thing to make sure everything is on nice and tight, then take the entire thing out as a unit. You will have to find a way to disconnect the exhaust (exhaust manifold or lower down)
If taking the trans with it, its one more mount, but then you need to remove axles and all that jazz
Sntucson
Aug 1, 2019 11:27 AM
uberEFtuner
Mar 4, 2012 08:27 PM
biggjerryc
Jul 7, 2008 08:42 PM
