Seized tie rod set nut
Old Feb 6, 2023 | 11:53 AM
Yellow del sol's Avatar
Default Seized tie rod set nut
So I have a 93 Del Sol and I'm changing both the tie rod inners and outers but as of right now I'm going to just do the outers, but I cannot get the set nut unseized no amount of wire brushing penetrating fluid or torching it is getting it free. I cramped up trying to use all of my strength to break it free any suggestions? Or should I just say screw it and take off the inner and do my best to make the lengths the same and guesstimate the alignment till I can get it to a shop.
Old Feb 6, 2023 | 12:10 PM
BeaterD16's Avatar
Default Re: Seized tie rod set nut
If you can remove the inners/outers at the same time, do that and save yourself the headache.
Old Feb 6, 2023 | 12:39 PM
All right kind of figured but I didn't know if there's something that would go screwy from doing that.
​​​​​​Thank you.
DaveAndAlex
Apr 23, 2021 12:23 PM
kaivorth
Honda Civic (2001 - 2005)
Nov 20, 2016 08:03 AM
wgbm92
May 25, 2012 12:00 PM
fracas
Feb 25, 2011 01:46 PM
VTECIntegra9
Suspension & Brakes
Aug 14, 2008 02:02 PM
