DRIVESHAFTS AXLES for Honda Civic EK Coupe with H22A swap
Old Jan 24, 2023 | 02:44 AM
Deep0's Avatar
Default DRIVESHAFTS AXLES for Honda Civic EK Coupe with H22A swap
Hello everyone!
I'm new here in forum, but I really need your help. We bought a race car, with H22A swap. When we bought it, driveshaft axle just got broken, so we used original driveshaft axle from B series honda crx. It fitted well, but my question is, that the only driveshaft axle that could fit? I find B series original driveshaft axles to be very expensive, and I'm sure there is some kind of axles that fits well too. Maybe someone who knows, could help us out? We already tried the Tegiwa B series driveshaft axles, they are too long and doesn't fit.
Our civic with h22a (147kw)
Old Jan 24, 2023 | 08:24 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: DRIVESHAFTS AXLES for Honda Civic EK Coupe with H22A swap
There is no inexpensive solution. Even the '88-91 CRX "B" series axles are incorrect... the inner joint on the right side is not long enough to stay snapped into the differential. Axle selection also depends on what mount kit is used as engine placement within the engine bay differs slightly between kits.
Old Jan 24, 2023 | 10:54 PM
Deep0's Avatar
As we know, the bearing is still from the civic, so there comes the question how is that. The front tyres have pretty big camber, if we would remove the camber, probably driveshafts woudl fit, but as a race car camber is needed.
Old Jan 25, 2023 | 09:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
What bearing are you referring to ? The issue with the inboard joint is that the H22 splined male joint is 1/8 - 3/16" LONGER than the "B" series axle, so the snap ring which locks the axle in place doesn't reach the snap ring groove inside the H series differential, and thus, why the "B" series axle will not work properly.
Old Jan 25, 2023 | 11:34 PM
Deep0's Avatar
You are right... Maybe you know, what kind of driveshaft axles could fit then? I'm out of ideas rn...
Old Jan 26, 2023 | 07:38 PM
JRCivic1's Avatar
10 Year Member
Community Builder
There is NO factory axle that you can buy that is correct for your application. There may still be some aftermarket companies like HASPORT or Raxles that produce what you need, but you will have to dig a bit. If you have the ability to build your own axles, here is what you need:
LEFT SIDE AXLE: '92-96 Prelude female inboard joint, '86-89 Acura Integra axle shaft and '90-01 Integra outboard joint.
RIGHT SIDE AXLE: '92-96 Prelude male inboard joint, '90-93 Acura Integra axle shaft and outboard joint.
Old Jan 31, 2023 | 01:11 PM
Deep0's Avatar
I appreciate your knowledge. Thank you for information!
Dara Say
May 22, 2019 11:27 AM
Cdubz628
May 3, 2014 10:18 PM
Sebba
Jan 2, 2014 10:39 PM
H22ACiViC
Mar 17, 2002 06:49 PM
