Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Should I run-away from this HR-V
Old Jan 23, 2023 | 08:56 PM
wesleytodd's Avatar
Icon4 Should I run-away from this HR-V
Hi guys,
Getting a pretty sweet deal on 2016 HR-V. However, there is some noise coming from serpentine belt area. Is this a major or minor repair?
Old Jan 24, 2023 | 08:09 PM
Ryanthegreat1's Avatar
Default Re: Should I run-away from this HR-V
Sounds like the bearings on the AC compressor pulley. It changes when the AC clutch is pulled in.
About $60 bearing and an hour or so of labor to make right.
Old Mar 6, 2023 | 06:19 PM
johnnybgood1's Avatar
Just need an ac clutch kit and a 2 arm puller to get the pulley off if you can get the compressor off so that you can turn it and get a puller on it. Then tap it back on, only tapping the inner race of the bearing pulley so you don't damage it and use the correct shims to make sure the air gap is within spec. It's diy but you might wanna just have a shop do it.
ssidenable
Oct 10, 2014 08:37 AM
5thGeneration
Nov 11, 2007 08:46 PM
ludetuner
Oct 28, 2004 05:46 PM
