Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
DTC:PGM-FI
Old Jan 23, 2023 | 05:24 PM
ELGUPASO's Avatar
Icon4 DTC:PGM-FI
I have an 2005 TSX and was working on a P2279 code to fix my air system leak, which I did. As I was running the scan tool again, I got the following DTC code. I first ran the BlueDriver scan tool and after that the Foxwell scan tool just to see if it would pick it up. Can anyone advise what it means or how to fix this? I had read up on it and some searches I found was the Main Relay. Any help would be appreciated.
Old Jan 23, 2023 | 05:37 PM
Ryanthegreat1's Avatar
Default Re: DTC:PGM-FI
Clear it and see if it returns. Super common to get additional faults in the ABS unit when there is a stored code in the PCM for whatever reason.
I had a VTEC pressure switch DTC and it caused a DTC in the ABS for module failure. Fixed the pressure switch issue and both codes went away.
lou1sette
Honda Civic (2006 - 2015)
Aug 6, 2018 06:37 PM
DA_Boy_626
11
Oct 16, 2007 10:48 AM
EJ ITO
Feb 28, 2007 05:56 AM
South sol
Nov 4, 2003 06:55 PM
