Purge Valve 36162-P0G-A01 discontinued, is there an alternative?
Old Jan 17, 2023 | 07:00 AM
akn01's Avatar
Icon4 Purge Valve 36162-P0G-A01 discontinued, is there an alternative?
1997 Honda Accord 2.7v6 uses Purge Valve 36162-P0G-A01 Honda says discontinued, all interchange I have found are not in stock or discontinued. Does anyone know if there is another replacement that will work for this car? Check engine light P0441. Or does anyone have a working used part available?
Old Feb 9, 2023 | 06:51 AM
Xist's Avatar
Default Re: Purge Valve 36162-P0G-A01 discontinued, is there an alternative?
I don't see any on Google Shopping, car-part.com, or LKQonline!
I can only suggest scavenging junkyards!
Old Feb 14, 2023 | 05:02 AM
akn01's Avatar
Yes, the junkyard search has not gone well. Does anyone know if another device (brand or model) can be used here? Is this NO or NC? I cant imagine this thing does anything that unique as to require this exact fit. If we need to adapt the plug or tubing that is fine. Car is dead for emissions with this check engine light on.
Old Feb 14, 2023 | 09:02 AM
akn01's Avatar
thanks @tech8 !
Old Feb 14, 2023 | 09:57 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Originally Posted by akn01
thanks @tech8 !
I posted and deleted some info. that was not accurate, since cross-references did not fully confirm the parts or they aren't available anymore.
Old Mar 30, 2023 | 10:03 PM
tayabijaz's Avatar
Hi, I'm having the exact same problem with my accord right now. did you figure out any alternative?
I'd really appreciate any help
hondaaccord88
Jun 27, 2022 04:53 AM
Doglover8978
Jan 18, 2018 11:58 AM
1ATony
Jan 28, 2011 08:05 AM
