Ive gone through 3 different sellers, every one of the listings shows the correct part number and will show the correct picture, and I will receive the same standard crap small inlet opening idle air control valve.
I found a seller recently with a proper break down of part numbers. If you are trying to order this part in the future be sure you find a reputable seller on ebay. The two incorrect idle air control valves I received were refunded by the sellers, but they will cause your car to idle from 3000 to 3500
Heres a picture I took compared to my original.
You can see physically the generic part i have been getting sent from ebay doesnt match up
And yes ive tried cleaning the original part, but its a dead motor. Basically idle is at 1100 rpms and doesnt respond to voltage.
If youve read this far here is a picture of my daily driver for the past 6 years. I leave it bone stock and its been an amazing daily to this point
