Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Honda civic heat and ac not workingb
Old Jan 5, 2023 | 06:09 PM
helpmyhonda202's Avatar
Default Honda civic heat and ac not workingb
Need advice on malfunctioning car heat and AC- Please help
Bought a 2011 civic in late june, with AC not working at all. Replaced the condensor, still didn't work. replaced compressor, still didn't work. replaced the blower motor, still didn't work. charged all systems, coolant, everything. no leaks, resister works.
It "worked" after all that, it would blow for about 45 minutes until it dimmed away and eventually no longer blowed any air. Usually when I started my car, if I felt air blowing it would work good for an hour. About 15% of the time, when I started my car, it wouldn't blow anything, and I knew it wouldn't work good
I should also note that when it would shut off after 45 min of driving, if I stopped and turned car off for 25-40 minutes it would work again.
For 3 days straight the air wouldn't blow at all when I turned it on, when it was like -10 degrees outside
I got someone to look at it, and they took out the air filter, and it was absolutely disgusting, we replaced with a new one.
Now, after replacing the air filter, the air literally blows so faint no matter what. and it shuts off after maybe 5 minutes. If you unplug the compressor(?) (could be condensor, idk, some1 told me) it would blow better, but now after a few days even if I unplug that it doesnt work at all barely.
Maybe its a rats nest in the resistor, motor? No idea. At this point I've spent $1000 in AC and Heat.
these problems are both AC and Heat, both with shutting off with driving and now neither blows.
Anyone have any suggestions on what it could be? Its also not the blend door actuators or whatever.
Edit
Old Feb 16, 2023 | 06:24 PM
johnnybgood1's Avatar
Default Re: Honda civic heat and ac not workingb
Edit
Your problem is likely the expansion valve is bad and is not regulating the flow correctly, allowing it to freeze over. When it defrosts it works again.
Replace the expansion and see if that fixes it.
helpmyhonda202
Honda Civic (2016 - Current)
Jan 19, 2023 12:27 PM
jties
Honda CR-V & Element
Sep 1, 2016 12:31 PM
MUGENVX9
Honda Civic (2001 - 2005)
Mar 7, 2013 06:20 PM
foxfai
Jun 22, 2005 11:30 AM
TedR719
Jun 7, 2004 11:58 AM
