3 to 2 Wire IACV
Old Jan 5, 2023 | 06:03 PM
jayEkhatch's Avatar
Icon5 3 to 2 Wire IACV
Hello Does anyone know out of the 3 wires for the iacv which are power and ground I know the orange wire won't be used so I have that cut but the pigtail I have has red and black wires so I am trying to figure out if the yellow/black is power and if the black/blue is ground?
Old Jan 5, 2023 | 09:54 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 3 to 2 Wire IACV
It shouldn't matter which wire goes where, but just to help with some direction, the original plug has the Blue/Black wire (ground from ECU) on top - closest to the lock on the clip. The Yellow/Black wire (12v Positive) goes on the bottom of the plug.
Old Jan 6, 2023 | 07:58 AM
jayEkhatch's Avatar
Thank you, I will go ahead and try that today and come back with the outcome.
Old Jan 6, 2023 | 08:08 PM
jayEkhatch's Avatar
So the good news is it worked bad news is the car kept revving up and down even after trying 7 different ecus all vacuum ports which could be a potential leak were capped off but nothing worked. but I would like to thank you for your help as this was my first time on the honda forums I have decided to sell the car after I put everything back as this has been pulling my leg all week.
prelude182
Feb 24, 2011 11:23 AM
90_EX_Civic
Mar 21, 2009 07:59 PM
solerizr
Mar 3, 2007 07:46 PM
Racermech
May 23, 2005 08:29 AM
NathanMorris
Jul 14, 2004 09:45 PM
