K24 eg header hitting subframe
Old Jan 3, 2023 | 07:43 AM
Chev's Avatar
Default K24 eg header hitting subframe
Hello, wanted to see if anyone knows a header I can purchase that will clear the subframe in my eg with the hasport egk2 mounts in the highest setting.
Running a k24a2 and I want the ground clearance if possible, have a header that is currently hitting and I can only use it if I lower the motor down. Any help or solution would be appreciated, I only need about an inch of clearance.
I would prefer not to knotch the subframe and have no issue buying a different header.
​​​​​​Thanks!
Old Jan 4, 2023 | 08:11 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: K24 eg header hitting subframe
What header do you have now ?
Old Jan 4, 2023 | 08:15 PM
Chev's Avatar
https://jackspaniaracing.shop/produc...4cc4e5a6&_ss=r
This is what I'm currently running now. Fits my friends k20 eg fine, just touches the subframe in my k24 eg on the highest setting, fits fine if I drop the motor to the lowest setting, but would like the oil pan clearance lol.
Old Jan 4, 2023 | 08:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
If you are trying to stay in the lower cost product price range, I suggest you purchase the PLM K24A swap header.
Either of these should work:
https://privatelabelmfg.com/collecti...header-rb-k20#
https://privatelabelmfg.com/collecti...amhorn-header#
Old Jan 5, 2023 | 04:34 AM
Chev's Avatar
That RAM horn one looks like it would work, as the only thing hitting the subframe are the runners. Definitely going to see if I can sell my current one and use the money for that header, I appreciate the input and will update if this clears it.
Thanks!
GYChris
Aug 24, 2009 11:02 AM
H22Stew
Dec 16, 2008 09:44 PM
accordselux
Feb 15, 2005 12:34 PM
91integraLSVTEC
Jul 30, 2004 02:02 PM
93hatched_projekt
Jan 18, 2004 01:27 PM
