I replaced the oil pan in my 1999 Accord 2.3L and there is oil on the mating surfaces
Old Jan 1, 2023 | 11:13 AM
Xist's Avatar
Default I replaced the oil pan in my 1999 Accord 2.3L and there is oil on the mating surfaces
The old gasket was leaking, so I bought a Fel-Pro, but everyone said it was guaranteed to fail, so I bought Hondabond, like the factory service manual recommended. Unfortunately, the paint started coming off inside, it began to rust, and when I used a can of gasket remover it removed the paint, just like it wasn't supposed to! I sanded, primed, painted, and cured in the oven, according to directions. The Hondabond says that it takes 3 days to fully cure at 77°F (25°C) and 50% humidity. People said to place a heater near it. I had a 1,500w heater as close as I could get it for most of a day and I taped bubble foil insulation around the front to keep out the wind and to keep in the heat. When that didn't seem to do anything I bought an oil pan heater and ran that for most of a day, with the bubble foil insulation.
Do you think the Hondabond didn't cure properly or the oil is leaking from above?
MumBleZ_94gsR
May 30, 2009 03:26 PM
JimmyM86
Honda Civic (2001 - 2005)
May 11, 2008 01:26 PM
uEDarkShadow
Jul 13, 2006 07:02 PM
PearlWhiteAccord
Dec 17, 2002 09:48 AM
Pinhead
Jun 9, 2002 01:53 PM
