Tucked harness ac wiring.
Old Dec 31, 2022 | 02:50 AM
Brokenfitting's Avatar
Default Tucked harness ac wiring.
Hello
just recently did a obd1 b16 swap on my 1998 civic dx hatch. I installed a tucked wire harness along with a tucked sun harness. I went to turn ac to see if it worked and it doesn’t. I’ve seen people say the ac is wired thru the sun harness I have extra cables for something they arnt labeled sadly and I’ve found pai outs saying it is wired thru the sun harness but when I look at my ecu pin out it has ac pin outs also. I am using the original ac system that was in the car for a d16y7.
so my question is where do I wire the ac in. Sun harness or ecu. Or both? Sure as hell hope it’s not the ecu would be a pain.
pin out I’ve been following below
Old Dec 31, 2022 | 09:29 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Tucked harness ac wiring.
What is a Sun harness ?
Old Jan 1, 2023 | 02:24 AM
damn… sub harness sorry. The harness for the cluster and stuff like that
Old Jan 2, 2023 | 02:38 AM
bump?
Old Jan 2, 2023 | 05:49 AM
bumpstick's Avatar
You need to wire the dash button to the compressor to turn it on, and the compressor to the ECU to compensate for the added load. Do you have a DMM? Trace out the flying leads on your harness and match them to the wires on your chassis. AC button comes from C131 and AC clutch goes to ECU. Terminate however you’d like (DT, barrel/shrink, etc)
Old Jan 2, 2023 | 11:46 PM
what’s c131? So are the pin outs I found correct. So I’d do the green plug(sub harness) and the ecu? How does the ecu pin outs work. If the engine harness doesn’t connect to the ac. Or am I doing a pin from ecu to green plug
Old Nov 13, 2024 | 04:30 PM
Keven23's Avatar
Any luck fixit it ?
_EF9
Nov 14, 2012 08:33 AM
Banks9697
Sep 19, 2010 02:28 PM
I Kick Squirrels
Aug 19, 2009 11:52 AM
boarderfatty
May 15, 2009 05:21 PM
limegrnxj
Mar 25, 2003 07:10 PM
