Weird noise only when I slowly take off 95 civic
Clutch in gave a little gas and slowly came off the clutch slowly took off it makes a rattle noise, you can kind of feel it on the floorboard of the car also this only happens when you're taking off though the car drives fine otherwise, any help is appreciated
If it sounds very metallic, it could be a loose exhaust heat shield. The heat shields are pieces of sheet metal bolted to the underside of the car around the exhaust pipe and they reflect heat down / away from the cabin. They can crack due to damage / rust, or a bolt may be missing, causing the rattle sound.
paintedsnow
Honda Civic (2006 - 2015)
May 6, 2013 01:31 AM
