JDM ITR seats in a del sol?.............................................. .
Old Nov 18, 2002 | 06:47 AM
4g4me's Avatar
Default JDM ITR seats in a del sol?.............................................. .
It is time for some new seats for my sol. I was thinking of getting the red JDM recaros that come in an integra. But here is the deal. Every search I do comes back with instruction on how to put integra or del sol seats into a 5th gen hatch, but never how to put them into a del sol. IF all you have to do is swap the rails to put sol seats into any other car, then i would only have to guess that the reverse procedure would be the same for my case. I would need to use the sliders for my del sol with the rails from the teg seats. The only thing I can see as a problem is the fact that when you put a del sol seat into a 5th gen, you lower your seating position about an inch, so would it work opposite for me? Would I be sitting 1" higher? That would not be too cool in my case. So if anyone has any information on this it would be greatly appreciated. TIA
Old Nov 18, 2002 | 08:02 AM
Looose_R's Avatar
Default Re: JDM ITR seats in a del sol?.............................................. . (4g4me)
youll sit higher, and i dont know if its as simple as jsut swapping rails. good questions though, i hope someone can reply with first hand expierence
Old Nov 18, 2002 | 12:46 PM
4g4me's Avatar
BUMP up
Old Nov 18, 2002 | 02:15 PM
function83's Avatar
use some sparco rails and use then bolt the recaro sliders on em.
Old Dec 3, 2002 | 09:02 PM
TomO's Avatar
If you swap the Dels sol rails on the Teg seats they should bolt right in. But like it was said, you will sit higher, by a couple inches. HTH
Tom O.
Old Dec 3, 2002 | 09:17 PM
JDM_Sol's Avatar
Default Re: JDM ITR seats in a del sol?.............................................. . (SonicGSR98)
let me know how it works out...thinkin of doing the same thing....post up pics if you do get it done ok?!...thanks....
mskansan
Apr 11, 2007 06:56 AM
Mrfeee1
Jan 28, 2005 11:59 AM
RiceBurninVTEC
13
Jul 27, 2004 07:38 AM
auto-x
19
Jan 20, 2003 04:44 PM
95excoupe
14
Jan 26, 2002 12:04 PM
