1998 honda accord acg fuse blowing
I have a 1998 honda accord that keeps blowing the acg fuse have spent 2 weeks so far trying to track down the short. Had melted wires connected to the main relay connects so I replaced them and soldered connections. Issue is still present. I have sense made a jumper with two mail ends on a piece of wire so that I could supply power to each individual circuit that recieves power from the acg fuse. None of the circuits cause the fuse to blow except the pin that has 2 yellow with black striped wires that go to the ecu. I since disconnected the ecu and fuses still blow. When relay is plugged in fuse only blows when car it turned over but when I direct connect the power to the ecu wire it blows immediately. I even ran a direct line from battery to the main relay connect with an inline fuse to bypass the green and white power wire but still blows. I have narrowed the issue down to the wires from Main relay connector to the ecu I believe but am not positive a since it blows even when not plugged into the ecu. Any insight or guidance is desperately needed!
timh
Audio / Security / Video
Dec 26, 2005 11:15 AM
chuckd05
Nov 5, 2001 07:33 AM
