Delayed fuel pump relay start after ignition turn on on rainy days
Old Dec 13, 2022 | 06:00 PM
jk93si's Avatar
Default Delayed fuel pump relay start after ignition turn on on rainy days
On rainy days, it takes about 5-15 minutes for fuel pump relay to engage in order to start the car. Someone told me I have a ground short somewhere. Car starts after a wire warms up and dispels the water or dampness. Where would this possible ground be so I can clean and tighten contact and rubber coat it and protect it from dampness. Thanks.
93 Civic Si Hatchback
Old Dec 14, 2022 | 08:37 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Delayed fuel pump relay start after ignition turn on on rainy days
More likely your ECU needs to have the electrolytic capacitors replaced.
Old Dec 14, 2022 | 08:38 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
This is the beginning of a failed ECU. There are components inside that fail over time... and right now, you only have an "occasional" failure. Eventually, it will happen EVERY time you try to start the car... and then it just won't start. Send it out to get repaired before you totally ruin it.
ssdjoey1904
Aug 6, 2014 04:48 AM
ej84dr
Jun 16, 2010 05:20 AM
Chuckyb
Dec 11, 2004 05:45 AM
-DC2-
Aug 4, 2003 09:58 AM
