2002 Accord need all seals
I'm currently rebuilding my F23A1 out of my 02 Accord. I need to find every seal in that engine including all the ones for the intake. It seems impossible to find them all. If there is a kit online I would definitely be interested or if anyone has diagrams of the seals with parts numbers it would be much appreciated.
~ Thanks
~ Thanks
For all OEM stuff, hondapartsnow.com or similar. Great resource for diagrams too. It's all available as a kit for the block, a kit for the head and intake manifold gaskets are piecemeal.
For non-OEM, budget conscious option Rockauto or similar should have an engine gasket set to include all common gaskets for a rebuild. Throttle body gasket would not be included, but would be available separately.
I would personally find you and make a list of all the gaskets and seals you would want to replace but they do sell kits. Like hondamark35 said, you can go oem or aftermarket. The "kits" tend to vary alot on whats included and may not include what you need or you may get parts you dont even need.
Also, its always nice to replace "everything" and "do-it-all" while you got it apart but honestly just spend the time to inspect really well and only replace what you need, its almost a better peice of mind knowing you got to replace yourself what was NEEDED and got it DONE.
