94 b18b tps?
Old Dec 9, 2022 | 09:20 PM
KaliKid's Avatar
Default 94 b18b tps?
Tried calibrating my tps but the max reading it does closed throttle is .22 with tps twisted maxed out any reason why?
Old Dec 10, 2022 | 06:44 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 94 b18b tps?
You likely don't have the tab on the TPS sensor aligned with the slot in the T/B shaft.
Old Dec 11, 2022 | 07:26 AM
KaliKid's Avatar
Ill go ahead and remove it and put it back when i get a chance and see if that was the problem.
Old Dec 11, 2022 | 12:36 PM
KaliKid's Avatar
Was able to take it off and back on made sure it was lined up and nothing still max it read was 0.18 CT
Old Dec 11, 2022 | 08:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
This means that either the TPS is broken OR you have a problem in your TPS wiring or ECU.
famous323
Dec 18, 2011 10:17 AM
95_red_dc
Apr 19, 2006 11:48 AM
bikeboy80
Oct 3, 2002 05:15 AM
