2000 Accord lost dash, gear select, and vanity lights
Hi all,
Need some help. So today I installed a number of LED lights in my wife's 2000 Accord SE. Swapped out the Dome, 2 map, 2 doors, trunk and license plate lights. While changing the sun visor mirror lights, they weren't coming on at all. Messed around, then realized that I needed the parking lights on in order for the visor lights to come on. In the middle of this I heard a click as if these mirror lights timed out or something. Then I could not get them back on at all. I called it quits at this point because wife now needed the car for work.
I thought all was good until wife called me tonight after her shift, and telling me if I did something to the dash lights. She said dash lights don't work, when she turned on the headlights. Also the Auto shifter gear lights not working either. Good thing the gear selection on the dash still worked and she used a flashlight on her dash to help her see how fast she was going. She found it very scary at night without all those lights.
After she got home I check out her car a bit, and now I noticed the license plate light is also not working. Could I have blown a fuse or something while installing the sun visor lights, hence the click I heard and then the lights went out. If it is a fuse would it be common to the other lights I mentioned.
I also watched a video about dash lights not working and it was tied to a box on the left of the dash which is common on these accords. But the vid didn't mention that it could take out other lights. I know where to check the box, but which fuses should I check.
TIA
TIA
distra
Apr 20, 2017 11:32 PM
tlbounds
Mar 7, 2016 05:56 PM
