em1 idle rpm’s bouncing
Old Dec 4, 2022 | 02:06 PM
ethanl44's Avatar
Default em1 idle rpm’s bouncing
I have a 2000 honda civic si that I just recently bought. Most of the time when i’m idling the rpm’s will bounce from around 1k to 2k over and over again. Anyone have any ideas of what’s going on ?
Old Dec 4, 2022 | 03:34 PM
Chance EG's Avatar
Default Re: em1 idle rpm’s bouncing
You mentioned in your other thread that you have a faulty distributor, so that most certainly could be a factor here.
Otherwise, make sure your IACV is clear of any debris. Check for any other vacuum leaks and make sure your TPS signal is reliable.
But, if you already know you have a bad distributor, fix that first.
Old Dec 4, 2022 | 04:55 PM
ethanl44's Avatar
Sounds good, thank you.
Old Dec 13, 2022 | 09:23 AM
The Mad Monkey's Avatar
Definitely check tps and iacv first. Seems to be the issue 90% of the time.
Tortugax626
Dec 12, 2019 09:56 AM
Jack jaxz
Engine Management and Tuning
Mar 22, 2016 04:29 AM
gabrielsousa
May 5, 2014 02:07 PM
Prozon
Aug 5, 2011 11:02 PM
