Phearable P28 Chipped ECU or JDM ITR ECU?
Old Nov 27, 2022 | 09:46 AM
ChrisOne22's Avatar
Default Phearable P28 Chipped ECU or JDM ITR ECU?
I have about $250-$300 max to spend and I could use some guidance. Here is my current set-up: 1998 Acura Integra GS-R B18C1 with 82mm USDM P72 pistons
- CT Engineering Icebox Intake
- OEM Integra Type R Intake Arm
- Skunk2 70mm Throttle Body
- Skunk2 Pro Series Intake Manifold
- Honda Civic Type R Camshafts (B16B)
- Skunk2 Alpha Dual Valve Springs and Titanium Retainers Kit
- Blox Lost Motion Assembly Kit
- DC Sports 4-1 Header
- Tanabe Medallion cat-back exhaust system
- Fluidampr Harmonic Damper Pulley
Based on my setup and limited budget for engine management, should I go with Phearable’s ECU chipping service (I have a spare P28 VTEC ECU w/conversion harness), or go with a JDM Integra Type R ECU (or other)?
Old Nov 28, 2022 | 08:43 AM
Relic1's Avatar
Default Re: Phearable P28 Chipped ECU or JDM ITR ECU?
the P73 is likely not going to get you where you want to be (it may be close)
the chipped ECU will at least get you to a point where tuning is an option in the future.
Old Dec 10, 2023 | 01:50 PM
ChrisOne22's Avatar
Relic1 - Really appreciate your feedback! I'll definitely look into Phearable's ECU chipping service instead of a JDM ITR ECU.
96DC2R
Apr 25, 2008 03:50 PM
1990_integra_DA9
Nov 13, 2006 05:17 PM
gsr squirrel
Dec 4, 2002 04:21 PM
kenji
Apr 8, 2002 05:33 PM
kenji
Feb 28, 2002 09:58 AM
