2000 civic ex Unknown oil leak
Old Nov 24, 2022 | 05:41 AM
VTECBABYYY's Avatar
Default 2000 civic ex Unknown oil leak
2000 Honda Civic ex, oil leak from under the distributor between the block and head. Shouldn’t be the distributor itself. Replaced distributor o ring, VTEC gaskets, and valve cover gasket all within the last 10 months. What could causing the oil leak?
Old Nov 24, 2022 | 01:35 PM
Jack Gorlick's Avatar
Default Re: 2000 civic ex Unknown oil leak
Clean it up good and rev it high, watch for it
Old Nov 24, 2022 | 04:04 PM
BeardedBaldy's Avatar
I have a similar issue, mine is due to the speed sensor on the transmission. I thought it was my distributor as well, but I remembered the bolt holding down the speed sensor is stripped on my transmission. It's leaking transmission fluid all over the same areas you're describing. Check that, worth a shot. Yours might just be loose, careful tightening it. Doesn't need to be super tight, just snug, There is an o-ring on the speed sensor as well, sits inside the transmission housing.
Other than that, there shouldn't be much else. Try wiping everything off, and check again after a short drive.
TXaggie
14
Aug 12, 2016 07:43 PM
glorious years
Oct 15, 2013 05:22 PM
Amelite
Mar 16, 2013 02:04 PM
otgarza
Jan 20, 2013 09:51 AM
MBlake55
Sep 2, 2011 02:19 PM
