92 Honda Accord DX problem car
I have a 92 Honda Accord DX that is sputtering when I hit the gas but runs fine at an idle I've replaced multiple fuel parts including the fuel filter fuel pressure regulator throttle position sensor I've even done the PCV valve it just had a whole tune up and timing belt replaced
Did anyone clean the fuel injectors in this process? It is cheap to clean with some basic tools by the way if you are of a DIY disposition.
Probably are. Just need to remove them and use a wire and 12v power source to open them up and spray injector cleaner through them. Nothing too fancy.
Total parts $7 for some cleaner lol.
allmotorchick
Feb 23, 2005 07:41 AM
