original actuators with third-party alarm
Old Nov 21, 2022 | 07:04 PM
arquin17's Avatar
Default original actuators with third-party alarm
friends I have a big problem in my Civic 97 I have an after market alarm installed and I would like to use the original Honda door lock actuators and not the after market ones someone has done it how is the procedure I have to add something else my alarm is a proto-security atomic 8
note the car has neither the original alarm nor the power source of the original lock actuators thank you all for your time and suggestions
Old Nov 22, 2022 | 08:53 AM
Sic_DA_Nine's Avatar
Default Re: original actuators with third-party alarm
convert the vehicle to have power options.
locks, door wire harness, floor harness, door panels, switches etc etc.
reinstall alarm to trigger factory power locks
Old Nov 25, 2022 | 06:26 PM
arquin17's Avatar
I have the original door wiring and original floor wiring what I do not have are the original keyless entry units as well as the original Honda alarm I have the original Honda actuators on the driver's side and on the passenger side checking in the forum they mention something from a relay but I don't know my current alarm is generic I just want it to control the original Honda lock actuators for more security since they are better than the generic ones
Old Dec 6, 2022 | 01:00 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Get a copy of the service manual, and sit down with it. I know you want an easier answer, but that's it.
Old Dec 7, 2022 | 02:02 PM
Relic1's Avatar
I use the factory actuators with an aftermarket alarm. you do not need the entire harness, just the two wires for each and a pair of automotive relays to actuate them. Done right it's as good as OEM or better. (search youtube for tutorials on the wiring, then get creative with the wire routing under the dash.)
Unless you are a stickler for OEM everything, then this vvv
mike500
May 13, 2017 07:29 PM
Wazup
Audio / Security / Video
Nov 16, 2009 11:47 AM
Nameless Warrior
17
Feb 24, 2007 08:42 AM
Rtzx9r
Honda S2000
Oct 17, 2006 04:24 PM
devilpuppy
Nov 15, 2004 12:46 PM
