2000 Honda Civic Si ECT
So I have a em1 with b16a. And it has a hard time starting/warming up. I’ve already changed the ECT and that only seems to be the issue and still get the code for it . I think that maybe the sensor is not getting any power whatsoever or ecu is just no good 👎🏾. I checked the wires already but at the end of the pigtail socket very little wire is exposed could that cause it to not work? Very weird
If you get a code for the ECT within a few seconds of key on/start up... the ECU has detected the lack of proper resistance in the circuit, so take a good long look at the wiring at the ECT plug and work back toward the ECU.
Alrighty thank you! I will keep an update on what it is
NEW Honda Acura EACV IAT ECT AIR COOLANT TEMP VALVE 2 WIRE Sensor Connector Plug | eBay
Gatoo_11
Oct 1, 2018 12:53 PM
speedracer001
Apr 20, 2005 01:02 PM
