VTEC Oil Pressure switch (code P2647)
The check engine light came on. Went to auto parts store since I don't have an OBD, and the code was P2647. They report said to replace the VVT Pressure switch. Does that sound right?
Also, the code 61-1 came up (break system low voltage) is this something to worry about, or is it a stored code from the last time my battery went dead?
Thanks,
Danny
Thanks,
Danny
That has got to be some kind of programming bug on the Hondas! I just got the same combination of codes on a TSX. Replacing just the VTEC oil pressure switch resolved both codes. The CR-V guys report the same combination of codes.
Since nobody else had an answer, I'll fill you all in on what it was. I took it to the dealer, and they replaced the rocker arm oil control valve ($348.17) with two hours labor ($370)
Did the 61-1 code for the battery go away as well?
Also, is the rocker arm contol valve the same as this?
"Variable Valve Timing VVT Solenoid for 2008 Honda CR-V"
fw190bvi
Jul 23, 2009 03:17 PM
drudy
Aug 7, 2005 05:59 AM
