Starts but I have to crank it too long
Old Nov 6, 2022 | 08:39 AM
Stock95delsol's Avatar
Default Starts but I have to crank it too long
OK, The little pos is on-the-road and I'm working-out the bugs. fixed cig lighter today and checked the TPS voltage again. It's very close so I'm going to leave that alone for now... The problem I have now is that I have to crank the engine for about 5x longer than I should have to to get it started. I have a Ford ZX2 with a Mazda drivetrain and it fires up immediately. "crank crank varrooom". every time. The Honda is like; "crank crank crank crank crank crank crank crank crack". I hate it. something is not right.... I have the TPS very close but not perfect. could this be the problem? fuel injectors? clogged fuel filter? THANKS
Old Nov 6, 2022 | 11:43 AM
White_EG1's Avatar
Default Re: Starts but I have to crank it too long
When’s the last time you did spark plugs the wires or cap and rotor?
Old Nov 6, 2022 | 05:21 PM
I have no idea... I've been working on two white, 95 del sols and i get them mixed up as to what I did to which car. I think that the timing is retarded. friend is going to lend me his timing light. the light I had for 40 years broke. pissed me right off....
Old Nov 7, 2022 | 04:40 AM
White_EG1's Avatar
You should replace those then, it should start up faster, if not you have other problems we can diagnose once you do a basic tune up to eliminate those.
Old Nov 9, 2022 | 10:00 AM
OK, I transferred the plugs from another good running del sol and that fixed the problem. the Denso plugs are KA-RAP. NOW, it lugs without jerking and drives without hesitating. THANKS for suggesting.... long ago I had a WS6 Trans Am that ran great but then after I let it sit in the garage for a year, it wouldn't start. no spark... I tried replacing a bunch of stuff in the distributor but still no spark. I had a guy come out to look at it and he suggested that I just buy a new, complete distributor and drop it in. I bought a cheap cardone distributor on ebay, dropped it in and it fired right up and ran great... sometimes a little obvious advice is needed because with these cars you can overcomplicate the problem. But what's odd is that the plugs would not fire properly under load ... I don't understand how that can happen. THANKS
MOE@Hyper16Valve
Jan 16, 2010 12:26 PM
flat-blk-HB
Jan 13, 2004 07:26 PM
